darklady310187's minimap mod
8 Beiträge
Gauner
I found this minimap mod in the German section, but my German isn't good enough to figure out how to install it since it is only an xml file. Could someone translate the essential points on installing it? I would think there should be no conflict with the English version.
The xml file is not the mod. Just copied everything into google translate to check. I am no modder and it would take a while to translate even from google to 100% English. But it does look to entail extracting archives, copying bsa files and scripting in the cs editor.
“You have your way. I have my way. As for the right way, the correct way, and the only way, it does not exist.”
“I do not love the bright sword for it's sharpness, nor the arrow for it's swiftness, nor the warrior for his glory. I love only that which they defend” J.R.R. Tolkien quote
Schurke
- Danksagung erhalten: 2 Mal
Androktone hat geschrieben:Just use the mod from TES Nexus -- it's comaptible with Nehrim.Thank you. Got it up and working.
Well, after 10 minutes faffing about. Decided to create an omod (first time). Then after a lot of cursing realised it was installed to Oblivion directory.
Nice mod for someone who has no sense of direction.
Gauner
*Edit* Nevermind ... sigh ... seems my resolution isn't fully supported (1366x768) and that contriubuted to my problems. Once I figure that out, it will be perfect.
tandcemeson hat geschrieben:*Edit* Nevermind ... sigh ... seems my resolution isn't fully supported (1366x768) and that contriubuted to my problems. Once I figure that out, it will be perfect.Could always try windowed mode in a resolution that is supported.
Gauner
Sorry, guess I should have been more specific. You can create your own resolution settings, but I just didn't have the time to look into it when I posted. It was very easy to do while following the documentation.
8 Beiträge
