Name: Console the Console
Version: 0.2.2
Date: 24 X 2010
Category: Gameplay Effects and Changes
Requirements: Oblivion 1.2.0.416, OBSE 0018 and optionally Night Eye Shader
Switcher (an OBSE plugin)
Author: Androktone
Source: http://www.tesnexus.com/downloads/file.php?id=35275
Changes
0.2.2
-- 5+5 commands available.
0.2.0
-- 5+1 commands available.
0.1.0
-- initial version;
-- 3 commands available.
Preface
If you're interested in adding some other commands, let me know.
Description
Console the Console gives you a quick access to some console commands by
pressing -- by default -- LEFT SHIFT + Q/W/E/R/T/A, resp. As for now, there are
five available commands:
1. Set FoV to 90 and set Night Eye Shader to a value as in the INI file. If you
don't have Night Eye Shader Switcher, don't worry, your comp won't explode.
2. Set FoV to 75 (= the Oblivion claustrophobic default).
3. Toggle the menus/HUD off/on.
4. Toggle the free camera on/off.
5. Toggle collisions off/on.
Optionally, you can add five more commands/functions of your choosing to the
INI file. These commands will be accessible in game by pressing -- by default --
LEFT SHIFT + A/S/D/F/G, respectively.
Install and configuration
1. Extract the files to: %Path_to_Nehrim_or_Oblivion%\Data\
2. Configure the mod by editing the file "konsola.ini" -- instructions inside
that file. Or don't and use 5 default commands.
3. Start Nehrim (or Oblivion) Launcher or OBMM and check
"AK-ConsoleConsole.esp".
Uninstall
Delete the files "AK-ConsoleConsole.esp", "konsola.ini" and
"AK-ConsoleConsole.txt".
(In)Compatibility
I have no idea.
Tested with
Oblivion/SI 1.2.0.416
OBSE 0018 (0.0.18.6)
Nehrim EV 1.0.8.2
Known issues or "issues"
1. Switching off/on the free camera or the menus/HUD too quickly, like twice in
a half-second, may cause... something.
2. If you set FoV to 90, remember to set it back to 75 before you exit
the game OR set the file Oblivion.ini to read-only BEFORE you start the game.
Otherwise the Main Menu will be messed up.
Licensing/Legal
Do whatever. Don't drink too much beer.
[REL] Console the Console
1 Beitrag
Schurke
- Danksagung erhalten: 2 Mal
1 Beitrag
